Multifunction DAQ
Crahs while working with multiple USB-6002 on same machine
for an experimantal Setup I sometimes have to use 4-6 USB-6002 Devices (reading 2 sensors and controlling 1 motor each) on the same desktop machine running a sepreate LabView-exe (2014) for each USB-Device. This does work in principal, but after some time the LV-exe crashes, making long term measurements with this setup impossible. I tried front and back usb 2 and 3 plugs on the machine, but the problems just keeps coming back. Is this a problem most likely related to the LV-exe, the runntime engine or driver or might it even be a hardware problem on the desktop machine?
Tanks
HMBR
Message 1 of 1
(1,793 Views)
