Multifunction DAQ
Counter configuration DAQPad6015 (BNC)
Hi
Under DAQmx I'm using ctr0 on a DAQPad6015 to read in multiple samples from an external pulse source (position sensor) having variable pulse rate. I would like to acquire multiple samples in equal time steps (e.g 10000 samples at 1ms intervals). In this mode I need to supply an external clock source for the counter. I thought maybe I could use ctr1 as the 'external' source by setting it running in continuous pulse output mode before initiating the read from ctr0. I physically wire ctr1 output to the digital input port selected on the ctr0 configuration. I find in practice I can't run this output counter at more than ~40Hz[12ms on/12ms off] before I receive an error message suggesting the input is being overwritten before ctr0 data set can be written to output. As yet I haven't tried a true external source to clock ctr0 reads. Why can't I sample at a much higher rate without the data overrun occurring - using the aforementioned approach? Will I have more success using an independent clock source?
Trevor
Smiley Happy
(2,423 Views)
Hi Trevor,
Using the second counter as the external clock is fine.  The problem lies in the fact that the DAQPad-6015 probably cannot transfer data any faster than the rate you are using without overwriting previous data.  The counters on this device have a small FIFO for transferring data, so it will fill up quickly.  If it is important that you have a faster rate and a USB device, you might consider NI CompactDAQ.
Laura
(2,410 Views)
Hello Laura,
Many thanks for your reply. I suspected this was a hardware limitation, but it is sometimes difficult to interpret product spec. sheets with respect to a particular requirement - such as this.
The DAQPad box belongs to a colleague who asked for some assistance and may be disappointed with the outcome (such is life) - I'll pass on your advice re CompactDAQ.
Cheers,
Trevor.
(2,404 Views)
