Multifunction DAQ
Convert the analog signal output of the PCIe-6733 board to an SMA connector.
Hello. I am building an analog signal output system for ultracold atom experiments. I plan to use a PCIe-6738 to generate signals, and use an SHC68-68-A2 cable to connect the signals to an SCB-68A breakout box to separate the 32 analog channels. My question is: after the signals come out of the SCB-68A, can I directly connect them to my load via SMA connectors, without adding any additional protection circuitry for the PCIe-6738? Would such a direct connection affect signal accuracy or shorten the lifespan of the device?
(109 Views)
It all depends on what you connect to on the other end.
Santhosh
Soliton Technologies
(66 Views)
Do I need to calculate the loop current based on the load resistance? Regardless, does NI have any recommendations or manuals for designing such a circuit?
(59 Views)
The spec tell you +-10 mA in four quadrat  (you can sink and source up to 10 mA)
Nowbody else than you know the (complex) impedance network you want to drive or other external sources that are involved....
Maxwell (this old guy with his 4 laws 😉 ) will answer you your questions
(and maybe the are easy ways and shotcuts ... but who knows?  Maybe you? )
Greetings from Germany
Henrik
LV since v3.1
(38 Views)
