Multifunction DAQ
Continuous synchronized AI and AO on TWO M-series PXI-boards
Hi, there!
I have just succeeded in performing continuous synchronized AI on two PXI-boards (6229 and 6259) using the PXI_Clk10 backplane clock. My application is also supposed to generate continuous analog output through one of the boards. I have written both applications in separate projects and they work fine, but when I combine the AI and AO code in one VI and try to run it on the PXI-target, it fails. The AO starts, but the synchronized AI never gets past the first loop iteration.
Only one error message appears; labview claims that "..not all samples have yet been acquired". My bet is that this has something to do with a sample clock/Reference clock conflict. For the AO I left the source-terminal of the DAQmx Timing VI unwired to let labview choose the default AO sample clock. This should not be in conflict with the AI performed by the same card....?
I would be grateful for any help. Labview has an example of multi-function AI/AO, but this code seems to do things much the same way that I did. I will post my code as well when I'm back at work on Wednesday.
Einar
P.S. The AO does not have to be synchronized with the AI.
(3,168 Views)
Hello!
No code has been posted as of yet so I suppose that means that you have solved the issue, is that a correct assumption?
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(3,132 Views)
Hi, Jimmie!
Yes, I solved the problem by forcing the AO-task to start after the AI-tasks, but I'm not exactly sure what caused the initial conflict.
This didn't get me very far, however, as my pxi-system couldn't handle the workload of sampling 32 channels at 10 kHz while running the 10kHz timed loop containing point-by-point VI's that created the output.
...but that is another story 😄
Einar
(3,111 Views)
