I want to do a continuity testing of a cable during vibration. I thought of setting up an analog voltage output across a resistor and measure the current in series with the resistor. The cable will be in series with the resistor.
However, I am having some trouble setting up the USB-6259 to provide a continuous DC signal from one output channel while measuring the current with an input signal. How do I best set up the timing and sequence of these?
(Will log the measurements as well, preferably 2kHz with timestamp in csv/xls - but I think I know how to do this)
