Hello;
I'm not sure if I got your question. Assuming you are talking about the delay in between the acquisition of one channel and the next (the interchannel delay); that value can be set by the user.
If you don't specify the interchannel delay, the NI-DAQ driver sets that value as 1/Sample Rate + 10 u sec, per channel. You have the option to set that value yourself.
Hope this helps.
Filipe A.
