I am trying to run a motor using my PC so i need to assign a Constant analog output voltage. How can i do that in Labview 8.0? I have an M series DAQboard so i can't use any traditional blocks, it has to be express Vi's or DAQmx.
I think it did that because he clears the task at the end. Try
this modification of that vi. I added a loop that will keep the
vi going until you hit the stop button. Then the task will clear.
