Multifunction DAQ
Connecting analog voltage measurements to DAQs of PXI I/O modules
Hey together,
we would like to measure voltages with a bandwidth of up to 1 MHz, 40V by means of analog I/O module PXIe 6378.
This is the equipment we currently use for this purpose:
We connect the probes as single-end connection with AI- and AIGND being shorted. We would like to have a isolation inbetween several analog inputs, probably a differential connection would be better.
What is the recommendation for voltage measurements with the described setup of PXIe analog modules? Which voltage probes are recommended or which alternatives for measurements with I/O modules are out there?
Thanks in advance for your help,
Martin
(948 Views)
Accepted by topic author martinbaumann94
Hello Martin,
Here you can find all information regarding on how perform measurements on this modules.
__________________________________________
The best way to thank, is to give KUDOS
(888 Views)
Thank you for your help.
(868 Views)
