11-18-2020 04:58 AM - edited 11-18-2020 05:08 AM
Hey together,
we would like to measure voltages with a bandwidth of up to 1 MHz, 40V by means of analog I/O module PXIe 6378.
This is the equipment we currently use for this purpose:
We connect the probes as single-end connection with AI- and AIGND being shorted. We would like to have a isolation inbetween several analog inputs, probably a differential connection would be better.
What is the recommendation for voltage measurements with the described setup of PXIe analog modules? Which voltage probes are recommended or which alternatives for measurements with I/O modules are out there?
Thanks in advance for your help,
Martin
11-21-2020 07:22 AM
Hello Martin,
Here you can find all information regarding on how perform measurements on this modules.
11-26-2020 12:45 AM
Thank you for your help.
