Multifunction DAQ
Connecting a 4-20mA loop powered sensor to USB-6255
JoeKellyATI wrote:
Do I have the sensor wired up backwards to the diode?
Yes you do.  The current needs to flow out of the power supply, into the sensor, out of the sensor and then through the diode to the power supply return.  With your diagram, to current flows counter clockwise.  So to have current flow through the diode, it needs to be in the same direction as the diode is pointing (look at the diode as an arrow).  Otherwise, it looks like that optocoupler will work.
GCentral
Message 11 of 13
(908 Views)
Thanks!
Here is an updated schematic for future people who stumble upon this thread:
I'll purchase that optocoupler and call it good.
Thanks everyone!
Message 12 of 13
(896 Views)
Here's the final (working) schematic for the pressure switch:Pressure Switch Schematic_schem.pngThanks for all the help!
Joe
Message 13 of 13
(832 Views)
