03-02-2013 11:21 PM
Hello everyone.
I want to connect a three wire proximity sensor to ni9401 to get the signal.
There are three wires on the proximity sensor-blue black and brown.
I am using a ni 9923 connector.
Please tell me how to make the connections.
03-03-2013 07:22 AM
Since you didn't provide any information about your proximity sensor, I can't say for sure, but in my experience proximity sensors usually output analog signals, not digital. You are using a 9401 - which is a digital card.
You might be able to get it to work if all you want to know is "is something there or not" but that's it.
I think you need to energize one of the wires, read a second, and the third is common voltage.
03-03-2013 08:55 AM
Thank you for your reply.
I am trying to sense a metallic plate ( which is rotating) to measure the it RPM.
I tried to connect the sensor in the 9923 connector as
brown wire: terminal 14.
Red wire: terminal 16.
Black wire: terminal 1.
Where
red-positive
black-negative
is this connection right to get pulses from the device.
03-03-2013 09:20 AM
How can anyone possibly know? You have not provided the make and model, a link to the datasheet, or much more than some colors.
03-03-2013 11:22 PM
The Proximity Switch we are using is
Type: ST18-3008NA
U: 6-36VDC
I: 200mA
Sn: 8mm
NPN
Is it possible to connect this proximity switch to ni 9401 through ni9923 connector.
03-04-2013 06:19 AM
can you tell us the manufacturer - googling the model did not bring up a link to the data sheet.
