Multifunction DAQ
Connecting Differential Voltage Signals to the NI 9207 avoiding use 1M resistor for each channel.
I was measuring voltages directly only connecting NI9207 (AI0+ and AI0-) and voltage source (+ and -), I got wrong readouts. I tested using a know voltage source and comparing multimeter value with NI-MAX task (see Ni-MAX task.JPG) for checking.
Using the configuration like wiring.JPG the problem was resolved. But I have to use a 1M resistor for each voltage channel for getting right measurements.
Is there any solution for improve this scenario? I mean avoid using 1M resitor for each voltage channel
(1,337 Views)
You need at least one 1M  (or another bias current path). All depends on your source(s), how are they related to COM?
Or: What are your sources and how are they supplied and connected related to COM of the DAQ?
(See my signature: Ground is ...)
Greetings from Germany
Henrik
LV since v3.1
(1,296 Views)
