Greetings! Hope all is going well.
1) You should not have to configure the SCC in MAX as long as you select the physical channel in LabVIEW. This I assume you are doing with DAQmx function calls in LabVIEW. The same applies with SCC.
2) We have to make sure that we tell LabVIEW which physical channel you want to read from or generate to signals.
3) The configuring in MAX is required for customers who would like to test the configuration and working of their setup
4) SCC allows the signal conditioning on a per channel basis and answers that each channel is conditioned
5) Could you let me know more about what you mean - Why would I need to tell LV that SCC1Mod1/ai0 is configured at all?
6) To explain more on what you might be looking for example -
If you want to acquire a continuous frequency measurement using the DAQ device's internal clock and an SCC-FV01 Frequency Input module. You would select the "SCC1Mod1/ai0" corresponding to frequency channel 0 on Module 1 of SCC module carrier 1. You have to just choose that channel in LabVIEW.
7) You can look at the example finder and in the search tab use SCC and that should result in three examples.
😎 Setting the range of the signal in DAQmx will automatically configure the gain and the corresponding voltage in the SCC modules. The voltage range are directly mapped and DAQmx would take care of setting the fain.
9) Listed below are the power options.
I am assuming you are using pwr03 option
Thanks and hope this helps
Good luck
Avi Harjani
