Hi all,
I am in the middle of my system setup and I am using a PCI-6731 and SCC-68. My problem is that in the setup manual for configuring the SCC, after following the instructions for configuration either SCC-68 is not selectable on the drop down list (although SCB-68 is) or the cabled device drop down box is greyed out and the following error is highlighted: No digitizer is available. Please add a digitizer before configuring your SCC Connector block.
I have installed MAX 3.0.0, NI-DAQmx 8.8 and LabVIEW 8.6. I simply want the SCC-68 to be selectable.
Any useful input I would be very much obliged!
Kindest regards.
