12-19-2009 07:12 PM
I am trying to trigger off of a load threshold from a load cell monitoring load. It seems that the 9237 doesn't directly have that functionality like some of the analog in modules. I also need to capture a second or two of pretrigger data. My programming skills are at a CLAD level and was wondering if A: this is possible (which I thing it is running a bunch of loops) B: or if anyone has attempted this with any success?
Matt
12-21-2009 10:10 AM
Hi Matt,
With the 9237, you'll still be able to do an analog software trigger. There's a really good example here that you may find very helpful. The example was built for a 9233, but you can change the task to a strain/custom voltage with exe task to suit your 9237. I gave this a shot with a simulated device and it worked well. Let me know if you have more questions after checking that out. Have a good one!
10-12-2021 05:17 PM
HI,
The link is not working. Could you please provide the link again?
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
