02-08-2011 06:19 AM
HI,
What is the limit for the common mode voltage when using differential inputs in NI6250?
IN my application the differential voltage is few volts but with reference to ground, it is 80 volts.
Can it work?
Is this issue addressed anywhere?
Rafi
Solved! Go to Solution.
02-09-2011 01:28 PM - edited 02-09-2011 01:28 PM
Hi Rafi,
The 6250 is not able to handle such a large differential to ground. I've found the specification in the NI 625x Specifications.
