Multifunction DAQ
Collecting TC measurements with nidaqmx python module - rounding decimal place during measurement
Highlighted
I've been following this (https://www.youtube.com/watch?v=NMMRbPvkzFs) video to use the python nidaqmx module to collect TC measurements with a cDAQ-9172 chassis and 9211 card.
The following code is directly from the video (except I'm using my own DAQ):
with nidaqmx.Task() as task:
    task.ai_channels.add_ai_thrmcpl_chan("cDAQ1Mod3/ai3")
    while i < 30:
        data = task.read()
        print(data)
This prints out temperature values like this:
24.983256110305593
Does any one know if there is built in support via the module to round the collected data point down to 24.98? I can do this downstream if really need be, but I am specifically interested in knowing if I can record data points at 2 decimal places with the nidaqmx module instead.
thanks!
(123 Views)
Highlighted
Probably not. The API will return the data as a double precision floating point value. You'll have to do whatever kind of formatting you want later on, as suspected.
Nathan Murphy
Certified LabVIEW Architect
Hiring CLD/CLA in Southern California
DM for details
(58 Views)
