02-02-2022 02:08 AM
What PC connected DAQ system would recommend for connecting this pressure sensor: https://www.te.com/usa-en/product-U5244-000005-030PA.html? I am looking at USB DAQs and am not sure if I can do a plug and play with this sensor or I will need some sort of signal conditioning.
Also, if the DAQ has ports for connecting thermocouples directly without any signal conditioning that is the ideal DAQ I am looking for. Sampling rate of anything above 1KS/s is good. I need at least 12 digital I/O for powering the sensors (I don't know if any DAQ can output between 8-30V which is requirement for pressure sensor). I will be connecting 3 pressure sensors and 3 thermocouples.
02-02-2022 06:13 AM
My situation is simple. I get the pressure from a pressure sensor.
It returns 0...10 V for a -1...6 bar pressure
I just open the DAQ assistant (input => voltage) and returns the value. I set Continuous Values because I want to have the continous values. I set 100 Hz because I don't need so much values every second (and also 1000 Hz bug).
It works 100% fine.
Problem is : it's not calibrated perfectly. So I use the calibration. I have small differences. I attached the picture. But when I use the calibration I have the error (image attached). If I unclick "enable calibration" (meaning desactive it), it works.
I set from 0 to 10 V, what my sensor delivers.
Any idea what this is ? "specified value is smaller than the minimum value" "corresponding value : 10"
doesn't make any sense to me.... thanks so much if someone can help !!
02-02-2022 07:08 PM
Can you make this a new thread? Don't know why you replied to my question as not relating to my question
02-02-2022 07:48 PM
There are a bunch of options for USB DAQs.
Based on your requirements, you're better off with a 4/8-slot cDAQ chassis.
Do you've any budget?
02-02-2022 08:30 PM
1. Makes sense for thermocouples, but I ideally want a plug and play for pressure too (and sorry I meant to say anything below 1kS/s so 100S/s is fine for both pressure and temperature), is that available? If not, what external circuitry would I need for the pressure sensor provided with 1-5V out?
2. I wanted it so I won't need an external supply and makes the setup that much cleaner. But if it is not an option then I will just buy an external supply.
My budget is under $1000
02-03-2022 04:50 PM
1-5V signals are typically supported by almost all DAQs. It would be best to go with an external supply.
Your budget is a bit too tight to get a proper DAQ system that can support 3 TCs, 3 pressure sensors(1-5V), 12 DIO. If you will get an external signal conditioning for TC that in turn outputs 0-5V or 0-10V, you could fit some DAQ in your budget.
Please share more about the use of DIO, voltage levels, current drive capability, does it require any waveform generation ability?
02-04-2022 09:23 PM
Well with the $1000 budget how many sensors can I connect in DAQ not requiring external signal conditioning. I am ok going above $1000 is ideal value.
The main use of DIO was for powering sensors so seems like the DAQ can't give the power required for powering pressure sensors, so a 5V dc out is good enough for powering relays that I will also be using to control other equipment. Current drive of anything up to 500mA is good.
02-05-2022 02:00 PM - edited 02-05-2022 02:06 PM
Still, your $1000 budget is insufficient for your requirements.
Any digital output capable of driving more than 10-15mA will become a power supply, so, no, there is no digital input/output that can drive 500mA without an external supply.
Let us take USB-6003 ($600) and analyze fit for your requirements
Now, you could observe why the <$1000 low-cost DAQ cannot fit your requirements without a lot of external circuit components.
Just a USB 4Ch 14S/s Thermocouple DAQ costs $800 (directly plugin the TC) - https://www.ni.com/en-us/shop/hardware/products/usb-temperature-measurement-bundle.html
USB-6525 ($400) is a good 8ch DI and 8ch DO for industrial use up to 60V (with external supply) and control 500mA loads using the SSR on DO channel - https://www.ni.com/pdf/manuals/371818b.pdf
02-06-2022 06:32 PM
If your budget is tight, give it a try on https://www.mccdaq.com/ - they got some low cost DAQs
02-06-2022 06:56 PM
What are the options available if I had a higher budget say $3000?
