09-14-2010 09:24 AM
What is the best way to change units from C to F and back on the graph showing temperature vs. time?
Solved! Go to Solution.
09-15-2010 11:16 AM
I recommend making a case structure with a boolean control to toggle the case. Within the case, scale the signal for degC or degF, and also have a property node for the graph by right-clicking the graph»create»property node»Y-Scale»Name Label»Text and change the text to degC or DegF accordingly.
Best,
09-15-2010 02:04 PM
I think this may work.
Thanks, Adam
