06-02-2008 02:42 AM
06-02-2008 11:07 AM
Hi Windy
Can I ask a couple of questions about your setup? First are you trying to do these all simultaneously or at separate times. Second when you say that you are playing around with the settings in max what have you been trying.
Will you post some screen shots of the test pannel in max on each channel. You should be feeding your signals into pins 2, 5 and 8 and I cannot see why is shouldnt pick up a reading there. Does thye 6008 pass a self test?
I look forward to hearing from you
best regards
06-02-2008 11:44 AM
Hi Graham
The unit in question is 20 miles away, but I'll get some screenshots tomorrow.
In the meantime, in answer to your questions, yes, these are all happenning simultaneously. I have 3 while loops running concurrently, one for the digital input, one for the counter input, and one for the analogue inputs.
Regarding playing with the MAX settings, what I mean is that I've been changing between the differential and RSE settings, and no permutation seems to work.
The 3 analogue signals are differential ones, and are wired correctly (I've triple checked this!).
The strange thing is is that the first analogue channel, the digial input and the counter all work correctly.
Also, when I swap the 6008 with another one (I have 4 of these test configurations built) the same problem exisits, so I know its not a hardware problem, or is extremely unlikely to be.
Chris
06-20-2008 08:51 AM
