Hello John,
Thank you very much for contacting National Instruments.
It seems as if you had already configured your system in MAX in you currernt machine. If you are using the NI-DAQ API and trying to access channels that are configured in MAX (i.e Traditional Global Channels), you would need to include the configuration file to your new machines. You don't have to reconfigure your channels in each machine though. You could basically import your configuration file from your current machine to new machines.
In order to save your current configuration file, go to MAX» File» Export»all data. The saved configuration file can then be imported to your new machine where you want to use your application. On the target machine, go to to MAX» File» Import». Please note that if you try to import all data in the file, you could potentially delete existing configurations in your new machine. If you don't have anything configured in your new machine, then you could import all data, otherwise be selective in importing only the channels that you need to be present in your target machine.
If you want to deploy your code in an executable format, then you don't have to use MAX but you would need to include the aforementioned configuration file as a support file when creating your executable.
I hope this helps. Thank you again for contacting National Instruments.
Ayman K
