08-27-2019 01:26 PM
I have a PCI 6703 and used to work well in NI MAX with Test Panel. After I installing VISA, the original button of Test Panel disappeared instead of Test VISA Panel. I have checked the driver and DAQ configure and DAQ configure support are all installed. Are there any suggestions I can get the old Test Panel back?
08-28-2019 10:23 PM
Can you post a screenshot?
If you maximize the screen for NI MAX, does anything change?
08-29-2019 09:12 AM
