Multifunction DAQ
Can't install VeriStand to target computer
Hi all,
I'm trying to install VeriStand to my target computer but I got several errors. First, I get this error:
Then I decided to install DAQmx 18.6 and NI-VISA 18.5 to fix this problem. After I install these packages to my computer, I need to install them on my target computer:
When I hit Next button, I get this error:
Therefore, it does not allow me to update my packages on the target computer. By the way, my overall goal is to install VeriStand package on target computer. I'm not sure if this fixes my problem. Could you please offer me a solution?
Regards..
(2,250 Views)
Probably the problem is that Real-Time support wasn't added with your DAQmx  driver installation.
(2,188 Views)
Accepted by topic author gumushane
When installing NI-DAQmx on the development/host PC, make sure to install Real-Time support for LabVIEW and/or LabWindows™/CVI. This will install Real-Time (RT) images to the host machine which can then be installed on the RT device using the Real-Time Software Wizard in MAX.
(2,186 Views)
