Hi. I have bought DAQCard-1200 and I can not install NI-DAQ 6.6 for work with LabVIEW from CD. I have Win 98 SE. The first stage of installation passes normally, after that the computer is restarted and the installation a component for LabVIEW 5.0.1f begins. I do not see the text in dialogue windows. Help please.
Hi Vadim before I installed the NI-DAQ 6.6, I removed the older version (6.5) in the start/settings/control panel/software menue. That worked perfectly. If you have already mounted the 1200 take it out again and remove it from the start/settings/control panel/system menue (it might be installed as a different device, if you mounted it before you installed the NI-DAQ) good luck,
