Multifunction DAQ
Can't find PCI-6221 in MAX
Hi. I have difficulty to find PCI-6221 DAQ board in MAX. It can be found in Windows Device Manger. Any suggestions to solve this problem?
(4,445 Views)
In MAX have you tried View>>Refresh?
Hope it helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
(4,442 Views)
Yes, I did. Many times.
(4,440 Views)
It could be related to the version of DAQmx you have loaded. Which version do you have?
(4,438 Views)
9.2 2mx. I think it is the latest version.
I read a similar topic ( related to PCI-6110 ) in this forum say that this is because certain types of keyboards or mice were used.
Will this be the reason also in my case?
(4,426 Views)
I'm not sure. From what I recall the USB problems were related to HP computer peripherals. Not sure if those would effect your PCI board.
(4,424 Views)
Sometimes this weird behavior is caused by corrupted MAX database. Try steps from following KBs:
What is the Process For Removing MAX Database Corruption
MAX Database Corruption Removal Tool
(4,382 Views)
