07-21-2011 04:26 AM
One of our acquisition board does not appear to be self-calibrated. When I run a calibrating vi, I get an error message saying that the file DAQmx Self Calibrate.vi can't be located. I can't find it on my desktop with a manual search and I can't find it on my NI-DAQmx driver software install CD either. Anyone has any idea/suggestions?
Sam
07-28-2011 06:28 PM
Sam,
The DAQmx Self Calibrate.vi is located in the following:
If you can't locate the vi this way, then there may be an issue with your DAQmx driver and you need to repair it. To repair your DAQmx driver, do the following:
In the meantime, I am attaching the DAQmx CSelf Calibrate.vi to my post
I hope this helps.
-Larry H.
07-28-2011 06:30 PM
Sam,
You can also perform a Self-Calibration in Measurement & Automation Explorer. To do this:
-Larry H.
07-29-2011 03:32 AM
Thanks Larry,
I've reinstalled both LabView and the DAQmx drivers. I can self calibrate my board now but when I send a simple DC value to my board with MAX, I get an error saying that it can not access the self-calibration information, even though I can see the self calibration information myself in the Self Calibration information tab. I was suggested that my MAX could be corrupted. I ran the MAX database corruption removal tool (see link below), the problem persists.
https://decibel.ni.com/content/docs/DOC-12805
Sam
07-29-2011 07:56 AM
Sam,
1. What type of board are you using?
2. What is the exact error that it is telling you? (if it gives a number, that would be helpful)
3. Did you do the self-calibration in Labview or in MAX?
-Larry H.
07-29-2011 08:38 AM
Larry,
The board is a PCI-6722.
The error is: "Warning 200016 the board was never calibrated with NI-DAQmx API" ... and consequently... "the date and time are not valid".
I did the self-calibration using MAX. I also tried the self calibration from LabView but the vi I have couldn't find a sub-vi called <vilib>:\daqmx\miscellaneous.llb\DAQmx Fill In Error Info.vi
07-29-2011 08:59 AM
Sam,
What version of Labview are you running? Also what version of the DAQmx driver do you have?
Also, I'm attaching the Fill in Error Info.vi to this post. Include this into your daqmx library and try running the VI now. Does the device calibrate it self now?
-Larry H.
