11-15-2005 12:30 PM
11-16-2005 11:52 AM
01-03-2006 04:27 PM
01-04-2006 05:18 PM
Dear Steve,
You are probably having problems with NIDAQ 6.6 on Windows XP because NIDAQ 6.6 is not supported on Windows XP.
With older versions of NIDAQ, problems can occur if you don't fully uninstall the DAQ driver before you reinstall it. Make sure to uninstall all versions of NIDAQ and the Measurement and Automation Explorer from Add/Remove Programs in the Control Panel. Then reinstall NIDAQ 6.9.3. Do the test panels work now?
Have a great day!
Marni S.
01-04-2006 05:53 PM
Unfortunately, that did not work. I uninstalled NI-DAQ 6.9.3 and Measurement and Automation Explorer 2.2 through the Control Panel. I then reinstalled NI-DAQ 6.9.3 and rebooted the machine. When I opened up the Test Panels, they still didn't work.
Any other thoughts?
Steve
01-04-2006 06:34 PM
Marni,
Nevermind. The cards are now working fine. It ends up that the PR50-50F cable simply wasn't seated properly into the DAQCard-700.
Sorry to waste your time.
Steve
04-21-2009 11:54 PM - edited 04-22-2009 12:01 AM
I have problems with installing the DAQCard-700 on a PC. To get the slot to insert the pc-card i got a pci-card with Ricoh R5C485 chipset as you can find here.
The Device is correctly recognized by windows and other (newer) PC-Cards run properly.
My operating system is Windows XP SP2. It's an AMD Athlon 1800+ with 128MB of RAM on a Mainboard with SIS730 chipset.
I installed NiDAQ 6.9.3 and the DAQ-Card was found in the Measurement and Automation Studio. But when i want to start the testpanel for this DAQCard-700, the system just freezes.
So i installed the PCI-Card and NiDAQ 6.9.3 on another computer (MSI-7065 with Intel chipset, Intel Celeron 2,8GHz, 512MB RAM). When i want to start the test panel here, it seems to freeze, but after a while i get the message, that the DAQ-Card does not answer on the first IRQ-Level. Then i have input on the three channels that are connected. But i don't get any input when i want to use my DropTest software (seems to base on a version of LabView because it has the same icon)
For testing purposes i installed the DAQCard on a Toshiba CF-52 with Ricoh R5C486 chipset and everything worked properly. The testpanel runs and i get correct input in droptest software.
What can I do? Are there any options to change IRQ-Levels for this Card? I did just the same on all tree computers, but it only runs on the Toshiba CF-52 laptop.
Is the DAQCard-700 incompatible to PCI versions of PC-Card readers?
Please help me, because i need to get the card run on a static pc.
Klaus
08-10-2010 09:51 PM
Dear all,
I am using DAQCard-700 using NI-DAQ 6.9.3 and Labview 7.1 but I could not use it
After I install Labview 7.1, I cannot see my device in Measurement & Automation anymore so that I cannot use it. Please help me to solve this problem.
How can I make NI-DAQ 6.9.3 work with LabVIEW 7.1?
One more question. I cannot install NI-DAQ 6.9.3 driver for my DAQCard-700 on two other laptops. I checked for RunOnce registry, it is fine on my both laptop. Please give me idea?
Thuy NH
07-31-2012 05:20 AM
Respected Sir,
I am new learner of this area.
I am using labview 5.1, fieldpoint FP 1000, NI-DAQ 6.5, Field point explorer version 1.6, Measurement and Automation Explorer 1.0.1.
my probelm "connection to acquisition board was not found" when i run labview program is due to DAQ board was not there in my CPU, so o plan to purchase NI-DAQ board.
I also have labview 8.2 (since labview 5.1 compatability with 8.2), field point 5.0.1, NI-DAQ 6.9.3.
In my old computer in MAX >> DEVICE AND INTERFACE >> I saw AT-A0-10, but i do not know how to caarried out test panel.
I also heard
I would kindly request you to please help me which NI-DAQ board is suitable for me.
I do not know how many signals i need to acquire to buy NI-DAQ card.
Thanking You
Yours faithfully
M. Vijay
