Multifunction DAQ
Can multiple AI tasks be started on the same 6229 DAQ card
I am establishing DAQmx read tasks to run in 2 independent loops. One is
Continious samples and the other is Hardware Timed Single Point. Run
independently both tasks run and perform as expected. Running both in the
same
VI or 2 independent VI's give me a resource conflict (-50103). Are
multiple
tasks / or timing methods allowed on the same 6229 card? If not, what is
an
alternate solution.
(3,467 Views)
I have read that multiple tasks are not allowed on the same card.  Does that mean that all the tasks must be the same sample type and rate?
(3,466 Views)
Hello Peter,
Take a look at these resources which discuss this issue in more depth:
KB 2WT74JMM: Causes of NI-DAQmx Error 50103 "The Specified Resource is Reserved"
Discussion Forum: Running Multiple DAQmx Tasks Simultaneously
Discussion Forum:
DAQmx error -50103 for Concurrent Analog In Tasks
Regarding your second question, with DAQmx 7.3 and later, you can include different types of analog input channels in the same DAQmx Task, but these channels must share the same timing configuration, i.e. sample clock rate.
I hope this helps,
Travis G.
Applications Engineering
www.ni.com/support
(3,448 Views)
That answered my question, thanks.
(3,441 Views)
