Multifunction DAQ
Can an M Series card be used to output a stable sine wave with good frequency accuracy?
I am trying to generate a 3kHz sine wave tone at 20mV pkpk, with frequency accuracy of +/- 1Hz or better.  Can multifunction DAQ devices be used for this, and if yes what card would be best?  Is there another type of IO card that  would be better suited for this type of generation?
(3,040 Views)
As you can see in the specifications, the AO timing resolution of a PCI-622x is 50ns --> internal timebase of 20MHz.
20'000'000/3'000 = 6666.6 -->
  • 20'000'000/6667 = 2999.85 Hz
  • 20'000'000/6666 = 3000.3 Hz
Therefore, these Low-Cost M Series cards would be suitable for your application.
You may be interested in this related post about AI written by Kevin Price.
(3,033 Views)
