03-23-2009 12:39 AM
Hi Sir,
Can ZTEC ZT530PXI Waveform Generator be identified in NI MAX?
As I known, for the PXI platform, the devices should follow the guidelines for the PXI interface.
But I do not know ho to do it,
I will not send command to the device, I just want to know if the ZT530 could be identified in NI MAX.
Then I can know the cards is installed well on my system.
Does NI MAX support interface fo third party PXI DAQ modules?
Thank you,
03-24-2009 11:50 AM
Hi Newbie-2009,
Non-NI devices generally do not show up in MAX. They may show up in MAX if you have an instrument driver for that module from NI, but I didn't see any on the database for your device.
Sammy Z.
03-27-2009 03:08 PM
I am an application engineer for ZTEC and I happened across this thread.
The ZTEC ZT530PXI can be identified in NI MAX. The only prerequisite is you must use the VISA specific drivers located in your ZTEC Instruments\Cclass\Wave\Driver\sys folder, specifically you want use visasysC.inf. You can update the driver used for this device using 'Device Manager' in Windows. If you have any question or would like some help you can open a support case at ZTEC's support center and one of our customer support personal can help.
03-30-2009 09:57 AM
Dear Ajoos,
This is excellent information.
Thank you.
Sammy Z.
