07-25-2011 02:01 AM
Hi
I have got a USB-6501, and I want to use it as a frequency divider.
My clk generator output frequency is about 3MHz, but our system clk input frequency is 100KHz.
So I need a frequency divider factor about 32(2^5).
How the USB-6501 can be used as a frequency divider?
Thank you
Yafei Ye
Ti
07-25-2011 02:07 AM
Hi Yafei Ye,
Implementig frequency divider is so simple as using counter to generate continuous pulse train - however, you use external clock.
You can find directly example at "Using a counter to divide down a pulse train".
With kind regards,
Stefo
07-25-2011 03:47 AM
Hi Stefo
Thank you very much for your help.
I will try it.
Yafei
