I'm looking at an NI USB 6343 daqmx device. I notice that I can set the measurement to have an input configuration of NRSE. The documentation says it will take the measurement with reference to the AI sense inputs instead of system gnd. I'd prefer to keep the measurements as single ended instead of differential to take advantage of the higher measurement channel count.
My input signals are typically 0-12V. It would be an advantage to me to have the input range of the instrument be -5 to +15 instead of +/-10.
Can I set AI Sense of a NI USB 6343 to 5V to offset the input range?
If not is there another device that would have an input range of -5 to +15?
If not is there a recommended attenuator circuit I could put on the front end?
