Multifunction DAQ
Can I install an older version of traditional DAQ that support legacy DAQ with DAQmx for support of a new card?
I have a LabPC+ that works fine, but is not supported in the latest versions of NI DAQ.  I also have a 6024E that I would like to use.  I know that the version of DAQ that supports the LabPC+ also supports that 6024E, but I would prefer to use the latest DAQmx with this.  Is this possible?
(2,096 Views)
Hi Brain:
Doesn't look like it, the PC+ will only go up to 6.9.3 tradition DAQ
http://www.ni.com/support/daq/versions_legacy.htm
while the 6024E will go up to 7.4.1 traditional or 7.5mx or 8.0mx, dependiong on OS.
http://www.ni.com/support/daq/versions_pci_pxi.htm
I assumed these cards were PCI based.
I am not a DAQ expert, so hopefully someone can verify this.
(2,087 Views)
You are right.  Traditional 6.9.3 is the latest version of DAQ that supports the LabPC+ board.  My best suggestion would be to look into the new M-series line of DAQ boards.
These boards are supported by the newest version of DAQmx 8.0 (depending on your OS)
-Jeff
(2,065 Views)
