Multifunction DAQ
Can I change the resolution of ADC from 16 bits to 12 bits?
I am using NI USB-6211 DAQ device. For one of my application I need to use DAQ device to convert the analog input to data samples. Since, I am mimicking the function of a particular MCU, I need to use 12 bits ADC resolution instead of 16 bits resolution which this device has. Is it possible somehow to use this device and get 12 bit resolution?
Currently I am using DAQExpress and I am not familiar with LabView, but I am open to suggestions related to LabView as well.
Thank you!
Message 1 of 13
(7,920 Views)
If you read raw values (that is possible with DAQmx within LabVIEW) you could divide the results by 16 (or shift the results 4 bit right).
Regards, Jens
Kudos are welcome...
Message 2 of 13
(7,885 Views)
@JensG69, I tried to use logical shift function in LabView...but all I can see is 0...I am not sure why, if you can help me with that. Also, I don't think dividing raw data (integer values) by 16 will produce the 12 bit data because that's scaling...but 12 bit/16 bit is related to the resolution of the ADC.
Before sending the data to logical shift function, I can see the output properly on waveform graph and I am able to log the data however, when this data is passed on to logical shift function it just gives 0.
I have attached my project. Thanks!
Message 3 of 13
(7,828 Views)
You cannot change the resolution of ADC from 16-bit to 12-bit, the only option is to discard the resolution of the extra 4 bits at software level.
Santhosh
Soliton Technologies
Message 4 of 13
(7,819 Views)
@Santo_13, that is what I am trying to do here in my project, but can't figure out why it is not working.
Message 5 of 13
(7,811 Views)
OMG shifting 4 bit (and ignore the 4 bits) or dividing by 16 for integer values is the same, and yes, you need to adapt the scale.
Or you AND all unsigned integer value with 0xF0 ....:D
Greetings from Germany
Henrik
LV since v3.1
Message 6 of 13
(7,805 Views)
Okay, I did not get what you mean by "adapt the scale"? Can you explain more?
Message 7 of 13
(7,763 Views)
Adapt the scale means changing the V/LSB multiplier.
For example, for a +-10V range with 16-bit ADC, each LSB corresponds to 305.176uV
whereas, for the same +-10V range with 12-bit ADC, each LSDB corresponds to 4.883mV
So, the technique has to be read raw values from DAQ at 16bit, discard the lower 4-bits, now scale it with a new LSB value.
Santhosh
Message 8 of 13
(7,755 Views)
Thank you Santhosh for the reply. I am sorry I don't have much experience with LabView. I understand how each LSB corresponds to what value. But I couldn't find how to change this LSB value. Also I am unable to discard last 4 values. 😞
Message 9 of 13
(7,745 Views)
Accepted by averagejoeb
I hope this helps
Santhosh
Message 10 of 13
(7,736 Views)
