10-14-2021 02:15 PM
Good evening everyone ,
I am working on a project in python to acquire an analog signal output from inverter to analog input of USB6001. the problem is when I acquire an analog input in voltage every minute, I have a random values (-5V , -0.1V , 4V), in the same time my inverter is off normaly the value 0V should be displayed every minutes.
Thank you in advance
10-14-2021 10:16 PM
Please share the exact schematic of connections and the code you use to capture the data.
