I have the PC-DIO-96 card and the NI4350 (PCI Version).
I need to determine the appropriate cables and accessories for my application:
1. PC-DIO-96 * Gives and Receives Discrete Signals. * Need 3m Cable length. (Shielded or Unshielded) - 1 End will be connected to the PC-DIO-96. - Other End shall be mounted to a box where the wires carrying the signals shall interface with the connector.
2. NI4350 (PCI) * Receives Analog Signals for ADC. * Need 3m cable length. (Shielded or Unshielded) - 1 End will be connected to the NI4350. - Other End shall be mounted to a box where the wires carrying the signals shall interface with the connector.
What do I need?
MY GUESS:
======== 1. FOR PC-DIO-96: * QTY. 2 of CB-50 I/O Connector Block (to mount to box) * R1005050 (but this only comes in 1m and 2m, how to get more length?)
2. FOR NI4350 (PCI): * SH6868 Shielded Cable (5m version) * TBX-68 termination block (to accept signals and mount to box).
For the 4350 you're OK. There is no longer cable for digital than 2m. You can also use a single 100-100 cable and go to an SCB-100(this is a shielded box).
The only other way I can thinkof to get longer cable is this: Use a SH100100 cable from the DIO96 and the R1005050. See if you can order a 100-pin FEMALE cable end and backshell from www.amp.com(Tyco electronics); the sh100100 cable has male connectors on both ends. Then, you can change the male ended connector on either cable with the Female connector you order from AMP.
