07-21-2011 04:40 PM
Since you are not running your TDAQ based application concurrently with your new application, I would still recommend using DAQmx.
http://zone.ni.com/devzone/cda/tut/p/id/4344
If you must use TDAQ, you will need to develop a TDAQ application in VB or Labview (from examples) and compile them as DLLs. Once you have your DLLs, you can call them from your .Net application.
Eric
07-27-2011 04:55 AM
I use this code it works.
Dim ReadingVoltage
With AxCWAIPoint
.Device = 1
.SingleRead(ReadingVoltage)
End With
UserInterfaceTextBox.Text = UserInterfaceTextBox.Text & CStr(ReadingVoltage) & vbNewLine
Thank you,
Good NI
