06-01-2006 06:01 AM
06-02-2006 01:02 AM
hello,
DAQmx 8.0 or above does not officially support, nor has been tested with Borland C++. So though it may be possible to use some of the techniques mentioned in the document you mentioned to get it to work, it is not something that DAQmx 8.0 or 8.1 was designed to do. May be you should think about some other compiler to use these DAQ drivers.
Thank you.
Tanvir
National Instruments Japan
06-02-2006 12:09 PM
I updated the KB to include the Borland C++ library for NI-DAQmx 8.1.
It will take a day or two for the changes to show up on the web so I am also including it here.
Sal
06-04-2006 10:06 PM - edited 06-04-2006 10:06 PM
implib.exe
program in Borland C++ Builder's bin directory to create nidaqmx.lib
from the nidaq32.dll or the task was a bit more difficult?
Message Edited by Juliuzz on 06-04-2006 10:10 PM
06-06-2006 12:57 PM
The task was very easy. Our CVI program allows you to compile your CVI written code with Borland C++. If you have CVI installed and install DAQmx, you get the DAQmx library that will allow you to comiple your CVI DAQ programs in Borland C++. I simply take that library and post it in the KB for every new DAQmx release.
Sal
