Multifunction DAQ
Bnc 2110 can replace to USB 6212/NI 781003-01 ?
Sorry~ I need upgrade Win2000 to Win 10 so have two  question to ask everyone,
1.
I have BNC2110 with PCI-MIO-16E-1, can I upgrade BNC2110 to NI 781003-01/USB6212  ?
    Because my BNC2110 uses one Anain and one Anaout and one Trigger/Counter CTR0 OUT but NI 781003-         01/USB6212 only digital I/O no Trigger ,
2.if can upgrade , BNC2110' interface card PCI-MIO-16E-1 can no use , only use USB6212 ,
(1,752 Views)
Accepted by topic author yashow
Let me rephrase your question better,
You currently have a PCI-MIO-16E-1 and a BNC-2110 accessory running on Windows 2000.
Now, you want to upgrade to Windows 10 and looking for alternatives to replace your old NI hardware. You have chosen the USB-6212 BNC version as a suitable replacement.
Your requirements are 1 AI (Analog Input), 1 AO (Analog Output), 1 Trigger/Counter.
If you were to replace it, your question is whether just the USB-6212 BNC is enough or do you also need the BNC-2110 accessory to operate?
Please provide the following information,
  • Did you compare the analog specification and accuracy between the two hardware? does it satisfy?
  • What functionality do you use on the CTR0 OUT line on PCI-MIO-16E-1? generate a pulse train or measure the input pulse or trigger in or trigger out?
    • USB-6212 has counters onboard
Santhosh
Soliton Technologies
(1,732 Views)
Thanks Santhosh sir help me precise Confirm the problem, now I can clearly find the device specification and find the signal function to try to solve the problem, thank you very much
(1,684 Views)
