That's what I get for trying to be clever with html tags. I always seem to forget to close a bracket or a quotation mark. Here is the post as it *should* have looked:
Hi tk123,
Thank you for pointing out that some of the data on that webpage is currently incorrect. If you look at the readme file from NI-488.2 version 2.3, which you can download
here, it lists the ENET/100 as a supported device. While upgrading the driver does not always fix the dreaded blue screen, it certainly cannot hurt.
Also, what other versions of NI software and drivers do you have on your computer? This will be helpful knowledge if the issue persists after upgrading the driver.
Hope this helps!
john m
