06-09-2011 12:47 AM
Hi ,
I have a general question about the way I can use my NI 6212.
I want to program it using CVI but I need to know something before I start.
The NI 6212 is a simultaneously device which means it can generate / acquire in multiple channels but is it possible to set the device to acquire and while he acquire to do other things in the software...
Basically what I'm trying to understand is if this device is "stand alone" meaning you set it to acquire and at the time it acquire you can do other softwareloops....
06-09-2011 05:33 PM
Hi Kobi,
Yes, you can run other code within your DAQmx coding. However, do know that running other code within DAQmx loops may slow down your DAQmx reads which could lead to buffer overflows.
If you are wanting run code simulatenously, DAQ and other code, you may want to use multithreading.
http://zone.ni.com/devzone/cda/tut/p/id/3663
http://zone.ni.com/devzone/cda/tut/p/id/3066
Also, I'd recommend looking at the DAQmx examples located in C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\. You can check out what a DAQmx continuous acquisition looks like and how it allows for other code to run while it is acquiring.
Let me know if I misunderstood your question. I was a little unsure of what you meant exactly.
Allie
