I have already post this request on the french forum
I have a problem to use my USB-6008 on linux. I use Mandriva One 2007 ( 2007.0 ) I installed NIKAL16, NI-VISA-4.2.0 & nidaqmxbase-2.1.0. Installation looks fine.
When I run lsdaq, I have this message : [francois@localhost National Instrument]$ lsdaq -------------------------------- Detecting National Instruments DAQ Devices Found the following DAQ Devices:
NI-DAQmx
Base has found a device with incompatible firmware. You may need to
reload the firmware on a machine with NI-DAQmx installed for the
following device:
NI USB-6008 Serial Number: 012F42CB --------------------------------
I have not installed NI-DAQmx on my computer so this link is not sutable http://digital.ni.com/public.nsf/allkb/A3C7200E881696FA862570AD0050E8D0.
I have follow the procedure to switch firmware with a windows computer (
http://digital.ni.com/public.nsf/allkb/64BA7A1D64D3D5518625726D0066A780
). First with Vista and daqmx 3, secondly on XP with daqmx base 2.1 without any change.
Here is the result of some fonctions :
[root@localhost francois]# lsmod | grep ni nipxirmk 121780 1 nidimk 333024 2 nipxirmk niorbk 98100 2 nipxirmk,nidimk nipalk 1131856 6 NiViPciK,nipxirmk,nidimk,niorbk nikal 59744 3 nipalk usbcore 108160 7 nikal,usbmouse,ehci_hcd,usbkbd,usbhid,uhci_hcd [root@localhost francois]# lsusb Bus 005 Device 001: ID 0000:0000 Bus 001 Device 005: ID 413c:3200 Dell Computer Corp. Bus 001 Device 004: ID 413c:2003 Dell Computer Corp. Bus 001 Device 001: ID 0000:0000 Bus 004 Device 002: ID 3923:717a National Instruments Corp. Bus 004 Device 001: ID 0000:0000 Bus 002 Device 001: ID 0000:0000 Bus 003 Device 001: ID 0000:0000 [root@localhost francois]# ls -l /dev/bus/usb/004/002 crw-rw-rw- 1 francois root 189, 385 déc 7 09:40 /dev/bus/usb/004/002
