05-05-2021 03:38 PM
Thanks in advance for your help.
I have a PXIe-6739 AO-type output module. I would like to use one of the BNC breakout boards such as BNC2090A or BNC2110 with this module, but the following NI website post says that these breakout boards will not be compatible: 67xx Models : DAQ Analog Output Cable and Accessory Compatibility - NI
Is this true or am I interpreting the accessory compatibility information incorrectly?
Spencer
05-05-2021 06:20 PM
Yes, it looks like there is no 6739 compatible BNC accessory.
All this have to do with the difference in connector pinouts between the different family of cards.
