07-04-2012 03:04 AM
I am trying use my CJC of BNC-2120 thermocouple Ic sensor for temperature measurement,but I am not able to acquire it with M6289 mass terminator device.
Whenever I make labview program using DAQ assistant,using ai1 as physical channel and ai0 as temp ref for CJC(default in device),It is giving daq error that task is not specified.
I don't know what is the program whether 6289 can control temperature sensor directly or not.
Please assist me in this regard.
Anurag
07-05-2012 02:48 AM
Do you have a specific error code for us?
Can you please post your code too.
Christian
07-05-2012 05:51 AM
Ya sure,please have look at attachments,error code is 200486
Thanks a lot for the reply....
07-05-2012 06:07 AM
You need to configure the Build in CJC channel first and then select "Build In" at the DAQ Assistants configuration.
Christian
07-05-2012 07:45 AM
Hi Anurag,
could you solve the problem with this KB-Dokument?
Christian
07-05-2012 08:59 AM
Hi christian,
This option of changing properties is not coming for M6289 mass terminator device,so I can't change its properties to enable the CJC reference..
Anurag
07-05-2012 09:20 AM - edited 07-05-2012 09:20 AM
Anurag,
you have to be more specific with your explanations in order that we can help you!
I have absolutely no idea about what you mean with "this changing properties".
Another thing I want to be sure about is that we are talking about the same hardware. With "M6289 mass terminator" you are talking about a PCI/PXI/USB-6289 DAQ card, right?
Christian
07-05-2012 09:54 AM
Hey Christian,
These are specifications for my equipment: NI 6289 USB High-Accuracy (Up to 625 kS/s, 32 Ch, 18-Bit)
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209152-----> Link for device which I am using.
I have attached the JPEG picture of the device when I open my Measurement and Automation Explorer,You can have a look at it when I right click on my device,what options are coming out.
07-05-2012 09:58 AM
The image shows that the device is not present anymore since shows up in MAX in white with a red cross. It should be green if it is installed correctly and connected to the system.
Christian
07-05-2012 10:06 AM
Ya I know it not green because right now I am not in my office right so that's its not green.
By the way I got the way how to change settings.
Please check it once in the attachement if I got the right window or not.
