12-19-2007 01:52 PM
12-20-2007 09:14 AM
12-20-2007 10:34 AM
Hi Carassius,
Would you mind clarifying how you tested your setup? When you say you “tested with a PCI DAQ card, and it still shifts,” are you testing with a different DAQ card, and which one? When you “tested with a different board and it’s solved,” do you mean a different BNC 2090?
What happens when you ground the other inputs through bias resistors? Does the drifting voltage go away on CH0? With which mode are you measuring your signal: differential, RSE, or NRSE?
Data Acquisition: Checking Your Board Settings - Analog Input Mode
Field Wiring and Noise Considerations for Analog Signals
12-20-2007 01:40 PM
12-20-2007 02:06 PM
