Hello, all
I have an NI-6284 with two BNC-2090's which I am using in 16 channel differential mode. I have installed 100K bias resistors in the "B" position per the 2090 manual on page 2-11, but have not installed the bias resistors in the "A" position as it seems that it isn't necessary if the inputs ar DC-coupled, if I understand correctly.
The problem I am trying to troubleshoot is this: if I apply a 5V potential across any input, every input of the card registers as 5V, +/- a few hundred millivolts. if I apply a dead short across the adjacent channel, that channel goes to zero, but all of the others hover around 200-300mV.
Will installing the second bias resistor in position "A" take care of this? Any idea what is causing this? I'm not sure I understand why the entire board lights up when I apply in input to one channel.\
Thanks.
James Nisly
Sr. Development Technician
Timken Research
The Timken Co.
