I am trying to output small sections of a large waveform (43000 samples) in small 20 sample chunks out to three outputs. The reason that I am doing this is to have the ability start writing zeros to any one of three outputs if a limit occurs. For an example, in the attached file is a toggle switch on the front panel that causes the outputs to output zero volts. What I noticed is that it took over 20 seconds for this to happen. I hoped that this would occur in the next iteration of the while loop. If I use this same example with an E series board with AO Parameter set at FIFO empty and FIFO Transfer condition all works as plan. With the modified example on the at-ao-6 board I get an error stateing that the board does not sup port these parameters. My question is since the at-ao-6 board does not have parmeters in its instruction set that there is no way to redirect the FIFO transfer on this board. Also would there be any other work around to accomplish what I need. Thanks
