Multifunction DAQ
Are there compatibility issues with using labview 4.0.1 with a DAQCARD 6024E. Which Ni-daq version should I use? Operating system?
I recently purchased a DAQCard 6024E and am trying to set it up on a windows XP laptop. Labview 4.0.1 vis do not seem to function. Do I have some compatibility issues? Thanks
(2,056 Views)
Hello;
The oldest version of NI-DAQ that supports that card of yours is 6.6, which doesn't support Labview 4. Furthermore, the only NI-DAQ version that supports windows XP is the latest one, 6.9.2, and the Labview version that supports that same OS is 6.1.
Since you will have to upgrade Labview to be able to work with that DAQ card of yours, I advise you to upgrade to Labview 6.1, so you can work under XP also.
Hope this helps.
Filipe A.
(2,056 Views)
