Multifunction DAQ
Are AOGND and AIGND of USB-6366 X-series connected internally?
I'm trying to use USB-6366 X-series for analog output, but I can't find AOGND on the front panel, is it possible that AOGND and AIGND are already connected internally? Where can I get this information? I don't see that information on the datasheet.
(1,725 Views)
Hi NORTH1997
AOGND should be found at the pins highlighted below.
The grounds for the USB-6366 are tied internally, but you should be using the AOGND if you are using an AO channel.
Alex
Hardware Engineer
(1,700 Views)
What you show me is the interface of the 6636screw terminal, I am using a 6636 (BNC), their panels are not the same, as I showed you.
(1,678 Views)
The BNC shell/shield of the Analog Output is AOGND.
Alex
Hardware Engineer
(1,667 Views)
