I'll try to offer some tips. It looks like you are trying to set up two different triggers for an analog input. This can not be done. Some different options for you are to use pause triggering, reference triggering, or some sort of software triggering. Pause triggering will allow you to collect data when the voltage is above (or below) some trigger value. When the voltage drops below (or above) the trigger value it will no longer acquire data. Another option is using a reference trigger. You can set up a reference trigger to acquire a predetermined number of data points before and after a trigger. Another option might be to use your analog signal as a start trigger for a continuous acquisition. Then, in software, monitor the data being acquired from the trigger channel. When the trigger channel acquires some data that is below your trigger level, stop the acquisition in software (after you have acquired all of your post-trigger data points). I hope this information helps!
-Alan A.
